TwinTurbo.NET: Nissan 300ZX forum - Re: Leaking fuel from pcv hose
njz
on January 10, 2019 at 8:22 PM
posted by ChezZ
on January 10, 2019 at 06:17 PM
Remove fuel line from the filter and and return line
plug up the return line from the pressure regulator and pressurize the fuel feed to the fuel rail and listen for air leak. 40 -50 psi
ChezZ
18:17:25 01/10/19
Badly leaking injector or injector o-ring would be
jzack
18:26:14 01/10/19
Re: Badly leaking injector or injector o-ring would be
ChezZ
19:59:56 01/10/19
Actually that’s a good suggestion about a bad r
jzack
22:23:19 01/10/19
Re: Actually that’s a good suggestion about a bad r
ChezZ
22:35:36 01/10/19
I'm going to point out the obvious
CarolinaZ_TT
07:52:06 01/11/19
Re: I'm going to point out the obvious
ChezZ
00:02:56 01/12/19
Re: Leaking fuel from pcv hose -
njz
20:22:59 01/10/19
I still thinks it’s the fuel regulator or damper...
itsa300zx
21:10:01 01/10/19
Re: I still thinks it’s the fuel regulator or damper...
ChezZ
22:32:54 01/10/19
I was thinking apply vacuum with a manual pump
itsa300zx
22:51:35 01/10/19
Re: I was thinking apply vacuum with a manual pump
ChezZ
22:56:22 01/10/19
Yes, that’s what I would try. Just be ready to shut
itsa300zx
23:05:12 01/10/19
Re: Yes, that’s what I would try. Just be ready to shut
ChezZ
23:16:09 01/10/19
Probably best to do both of them...also I think the
jzack
23:25:14 01/10/19
